Alight Motion
Been thanked: 33 times
Alight Motion
Alight Motion v5.0.271.1002592 [Premium]
Requirements: 6.0+
Overview: Be part of the movement! Alight Motion is the first professional motion design app bringing you professional-quality animation, motion graphics, visual effects, video editing, video compositing, and more!
• Add multiple layers of graphics, video, and audio
• Vector and bitmap support: edit vector graphics right on your phone!
• 160+ basic effect building blocks that can be combined to create sophisticated visual effects
• Keyframe animation available for all settings
• Link parent and child layers and rig character joints
• Use Cameras that pan, zoom, and support focus blur and fog
• Group layers together and create Masks!
• Adjust Colors and change them as you wish!
• Animation easing for more fluid motion: Pick from presets or build your own timing curves
• Add bookmarks for ease of editing
• Make smooth videos thanks to the Velocity-based motion blur
• Export MP4 video, GIF animation, PNG sequences, and stills
• Share project packages with others
• Exploit our solid color and gradient fill effects
• Add effects to Borders, Shadows, and Strokes!
• Add text using the custom font support
• Copy and paste entire layers or just their style
• Save your favorite elements for easy re-use in future projects
Alight Motion requires at least 1.5GB of RAM to be installed and run effectively.
Terms of Service: alightcreative.com/tos
Privacy Policy: alightcreative.com/privacy
Bug fixes and improvements
This app has Credit advertisements
https://uploadrar.com/p90bwhuaw9r9
