[E² Plugin] Wireguard-Vpn
This Section Using About Download Software Vu Solo Receivers .....
sugar
Turkey
Post by sugar »
Update Online WireGuard VPN V.12.8
* Speeded up pinging both by page and by selection.
* Removed the option to ping all servers, it was useless
* Fixed execution on the NonSoloSat image (thanks pippomus for testing).
* Added support for the CobraLiberoSat image (thanks pippomus for testing).
* Built and tested on Python 3.13.
* Updated the French translation (thanks gruick1).
* Updated the Greek translation (thanks giorbak)
* Update .po and .pot files
thanks madhouse
Python 3.9 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .8_all.ipk
Python 3.11 (ARM - End of support): https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
Python 3.11 (ARM - End of support):https://github.com/m4dhouse/Wireguard-V ... .9_all.ipk
Python 3.12 (ARM):https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
Python 3.12 (AARCH64):https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
Python 3.12 (MIPSEL):https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
sugar
Turkey
Re: [E² Plugin] Wireguard-Vpn
#2
Post by sugar »
Update Online WireGuard VPN V.12.9
* Fixed "Quick Connect" feature (Thanks Zorro71)
Python 3.9 (ARM): https://github.com/m4dhouse/Wireguard-V ... .9_all.ipk
Python 3.12 (ARM):https://github.com/m4dhouse/Wireguard-V ... .9_all.ipk
Python 3.12 (AARCH64):https://github.com/m4dhouse/Wireguard-V ... .9_all.ipk
Python 3.12 (MIPSEL):https://github.com/m4dhouse/Wireguard-V ... .9_all.ipk
sugar
Turkey
#3
Post by sugar »
test
Python 3.13
enigma2-plugin-extensions-wireguard-vpn_13.0_all_py_3.13.ipk (2.49MB)
https://www.sendspace.com/file/ux80xv
sugar
Turkey
#4
Post by sugar »
Update Online WireGuard VPN V.13.0
* Now the plugin being initialized creates the configuration directory if a mount for external devices exists.
* Removed Ping option on NordVpn and Proton providers, servers respond late.
* Update .po and .pot files.
thanks madhouse
Python 3.9 (ARM):https://github.com/m4dhouse/Wireguard-V ... .0_all.ipk
Python 3.12 (ARM):https://github.com/m4dhouse/Wireguard-V ... .0_all.ipk
Python 3.12 (AARCH64):https://github.com/m4dhouse/Wireguard-V ... .0_all.ipk
Python 3.12 (MIPSEL):https://github.com/m4dhouse/Wireguard-V ... .0_all.ipk
Python 3.13 TEST (ARM):https://github.com/m4dhouse/Wireguard-V ... .0_all.ipk
sugar
Turkey
#5
Post by sugar »
Update Online WireGuard VPN V.13.1
* Added the Search by country (button 1) and reset (button 2) function.
* Fixed the ProtonVpn module, now displays the name of the country, added the missing flags.
* Updated Russian translation (Thanks airforce).
* Updated the German translation (thanks Tommy007).
* Updated the Greek translation (thanks giorbak).
thanks madhouse
Python 3.9 (ARM): https://github.com/m4dhouse/Wireguard-V ... .1_all.ipk
Python 3.11 (ARM - End of support): https://github.com/m4dhouse/Wireguard-V ... .9_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wireguard-V ... .1_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .1_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wireguard-V ... .1_all.ipk
Python 3.13 TEST (ARM): https://github.com/m4dhouse/Wireguard-V ... .0_all.ipk
sugar
Turkey
#6
Post by sugar »
Update Online WireGuard VPN V.13.2
* Added the ability in "Use personal files" to create configuration files for CloudFlare Warp (Free)
* Updated Spanish translation (Thanks Juan Romero)
Python 3.9 (ARM): https://github.com/m4dhouse/Wireguard-V ... .2_all.ipk
Python 3.12 (ARM):https://github.com/m4dhouse/Wireguard-V ... .2_all.ipk
Python 3.12 (AARCH64):https://github.com/m4dhouse/Wireguard-V ... .2_all.ipk
Python 3.12 (MIPSEL):https://github.com/m4dhouse/Wireguard-V ... .2_all.ipk
sugar
Turkey
#7
Post by sugar »
Update Online WireGuard VPN V.13.3
* Added stopping and resuming of the Sat/DTT service on channels with DNS or IP.
* Added ability to delete files from personal file settings.
* Now the search button on the NordVpn provider with country option is not displayed.
* Added ping on NordVpn provider.
* Updated Spanish translation (Thanks Juan Romero).
Python 3.9 (ARM):https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.12 (MIPSEL):https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
sugar
Turkey
#8
Post by sugar »
Update Online WireGuard VPN V.13.4
* Added ping option on personal files.
* Added support to SatDreamGr image.
* Small graphic fixes.
Python 3.9 (ARM):https://github.com/m4dhouse/Wireguard-V ... .4_all.ipk
Python 3.12 (ARM):https://github.com/m4dhouse/Wireguard-V ... .4_all.ipk
Python 3.12 (AARCH64):https://github.com/m4dhouse/Wireguard-V ... .4_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wi…ard-vpn- ... .4_all.ipk
telnet
Code: Select all
wget -q https://raw.githubusercontent.com/m4dhouse/tailscale_bin/main/WireGuard.sh -O - | /bin/sh
sugar
Turkey
#9
Post by sugar »
Update Online WireGuard VPN V.13.5
* Fixed ping option if Proton provider was previously selected (thanks Giorbak).
* Fixed save server list option in proton vpn (thanks Giorbak)
Python 3.9 (ARM):https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
Python 3.12 (ARM):https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
Python 3.12 (AARCH64):https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
sugar
Turkey
#10
Post by sugar »
Update Online WireGuard VPN V.13.8
* [NordVpn] Now only displays online servers.
* [NordVpn] Fixed the server by country option, now faster at populating the server list.
* Added Blue skin.
thanks madhouse
Python 3.9 (ARM):https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
Python 3.12 (ARM) https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
